[mapguide-users] Request for help inserting new row into SDF file.
Jackie Ng jackie.ng at aecsystems.com.au
Tue Feb 27 19:32:11 EST 2007
I don't think you can insert data without a geometry component in SDF files.
- Jackie
Matthew D wrote:
> I am attempting to insert a feature/record into an SDF file.  The record
> does not have any geometry.
> I have no problem returning data from this code
> $featureReader = $featureService->SelectFeatures($featureResId, $class,
> $queryOptions);
> The insert method doesn't seem to work AND does not give any error
> messages why not.
> $propertyValues = new MgPropertyCollection();
> $propertyValues->Add(new MgInt64Property('mow_id', 3));
> $propertyValues->Add(new MgInt64Property('seg_id', 2231));
> $propertyValues->Add(new MgInt16Property('percent_required', 100));
> $propertyValues->Add(new MgStringProperty('contractor', 'Mow Machine
> 65'));
> $propertyValues->Add(new MgStringProperty('mow_date', '20070202'));
> $propertyValues->Add(new MgStringProperty('comments', 'Some comments'));
> $commands = new MgFeatureCommandCollection();
> $commands->Add(new MgInsertFeatures($class, $propertyValues));
> $featureService->UpdateFeatures($featureResId, $commands, false);
> Could someone tell me if there is something I am missing, or if there is
> some way to find out why this is not working?
> Thanks,
> Matt
View this message in context: http://www.nabble.com/Request-for-help-inserting-new-row-into-SDF-file.-tf3303740s16610.html#a9195532
