[mapguide-users] WMS in a standard browser
Bjurström Jan Jan.Bjurstrom at lm.se
Wed Feb 28 03:46:39 EST 2007
Hello
I read the OpenGIS WMS implementation specification OGC 06-042 version 1.3.0, which says that  "Web Map Service operations can be invoked using a standard web browser by submitting requests in the form of URLs".
Have anyone of you opened a web map service in a standard web browser?
/Janne
Från: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] För Haris Kurtagic
Skickat: den 23 februari 2007 21:55
Till: MapGuide Users Mail List
Ämne: RE: [mapguide-users] King.Oracle FDO Provider ORA-12705 error
I am not sure what could be your problem.
If you are using standard Oracle client than It would be better to use version of King.Oracle provider for standard Oracle client.
If you don't have Oracle client installed then you should use version of King.Oracle provider with instant Oracle client.
Haris
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jon Vincent
Sent: 23. februar 2007 21:24
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] King.Oracle FDO Provider ORA-12705 error
Thanks for the response Haris.  I am using the standard Oracle client, and I tried renaming and deleting the NLS_LANG entry.  As mentioned in my previous post I also tried changing the value for this entry which you also suggested previously.  None of this has helped and I continue to receive the ORA-12705 error when I attempt to test the connection.  Any other ideas?
Thanks
Jon
Date: Thu, 22 Feb 2007 14:02:24 +0100
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Message-ID:
      <E4D44138BD8AF742AB4A08D3B717643A01EAAE at vmdc2003.sl-king.com>
Content-Type: text/plain; charset="us-ascii"
I came on this issue in situation where it was installed stanadard
Oracle client previously (as usually described on www if you search for
that error).
Solution was to rename or delete that nls_lang entry ( as suggested on
www).
If you still have standard Oracle client installed on machine you can
also use King.oracle for standard Oracle client version.
Haris
Sent: 20. februar 2007 22:45
Subject: [mapguide-users] King.Oracle FDO Provider ORA-12705 error
I am attempting to get up and running with the King.Oracle FDO provider
but I am having some trouble making the connection in MapGuide Studio.
I am using the 0.4.4 version, and I have the latest version of Studio
installed(1.0.0.17804), but when i attempt to make a connection I get
the error: ORA-12705: Cannot access NLS data files or invalid
environment specified.
I have taken a look at the HKEY_LOCAL_MACHINE\Software\Oracle\NLS_LANG
setting and I have tried renaming, and deleting it.  I added it back in
and changed the value to AMERICAN which is the setting for nls_language
for my database.  I can't find any other information about this and I
was hoping someone else may have some other suggestions.
Finally I'm running Oracle 9i (9.2.0.1.0).
Any suggestions would be appreciated.
Thanks
Jon
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070222/17cf27f4/attachment.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
End of mapguide-users Digest, Vol 2, Issue 97
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070228/badbc809/attachment-0001.html
