[mapguide-users] RE: Guestion about speedup mapguide,
diferent domainname to mapagent.fcgi.
Kencana
bluesky_dyx at hotmail.com
Wed Feb 28 21:44:17 EST 2007
the following is the url of my map. you can see that the map loading is very
slow.
by the way i am not using map tiled as because the map tiled initial view
took
longer time than the other one.
any idea of improving it?
http://202.172.177.8/mapguide/mapviewerajax/?WEBLAYOUT=Library://Web/YP%20SG%20Trial.WebLayout&LOCALE=en
Thank you very much
Regards,
Kencana
JasonBirch wrote:
> Paul wrote:
>> m1.google.com
>> m2.google.com
>> m3.google.com
>> and that each of these resolves to the same IP.
> And that IP address is probably a load balancer... I'm pretty sure that
> this single IP thing is not part of the performance measures.
> Traian wrote:
>> But then I decided that this can be worked around
>> by using a file system mount from the web server
>> to the server where the tiles are. I've seen a similar
>> thing done on Linux/Apache, not sure if Windows
>> could handle such a setup.
> I've done this with IIS (CIFS share) and, while I can confirm that it
> works, it's a pain to set up and the performance is very poor compared to
> local filesystem access.
> While this might be a good solution for some situations (like, where the
> tile servers are behind a firewall?), I think that it would be best to
> also have the option of being able to set up a local webserver on the tile
> servers to serve the tiles directly to the clients rather than having to
> do everything through the web tier server.
> Jason
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Guestion-about-speedup-mapguide%2C-diferent-domainname-to-mapagent.fcgi.-tf3307731s16610.html#a9242845
