[mapguide-users] RE: RE: Guestion about speedup mapguide, diferent domainname to mapagent.fcgi.
Jonathon jmatpat at yahoo.ca
Wed Feb 28 23:51:30 EST 2007
Is there only the tooltip column in the shape file?  Also, can you have
different layers for different scales that don't use tootips for the initial
map.
Be limiting tooltips/working with scales, we were able to take initial load
times from about 30 seconds to 5-8 seconds.  More in line with MG 6.5 with
ActiveX.
J
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kencana
Sent: Wednesday, February 28, 2007 8:42 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: RE: Guestion about speedup mapguide, diferent
Hi Jonathon,
thanks for the feedback. I am using sdf file for the source. well it is
actually from shp file and mapguide studio convert it to sdf file. as for
the tooltip, it is one of the compulsory thing so i guess i need to use it.
Thanks
Regards,
Kencana
Jonathon-12 wrote:
> Hi Kencana,
> I had a look at your site and agree that the performance is a lacking.
> I also don't know what your source is (SHP etc) but I have definitely
> found that the attributes attached make a huge difference (I started
> stripping out any data-it goes into a SQL Server database that I index
> as much as I can- in my shape dbfs that I don't use for tooltips and
> it helps a lot).  I also use tooltips and labels as sparingly as
> possible (if you can, allow the user to select the item to get
> attribute info).  It seems that there is a lot of information showing
> in the initial map view...can you remove some of the layers or thin
> the data, this helps.
> Hope that some of this might help...
> Cheers,
> Jonathon
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Wednesday, February 28, 2007 6:44 PM
> Subject: [mapguide-users] RE: Guestion about speedup mapguide,
> Hi,
> the following is the url of my map. you can see that the map loading
> is very slow.
> by the way i am not using map tiled as because the map tiled initial
> view took longer time than the other one.
> any idea of improving it?
> http://202.172.177.8/mapguide/mapviewerajax/?WEBLAYOUT=Library://Web/Y
> P%20SG
> %20Trial.WebLayout&LOCALE=en
> Thank you very much
> Regards,
> Kencana
> JasonBirch wrote:
>> Paul wrote:
>>> m1.google.com
>>> m2.google.com
>>> m3.google.com
>>> and that each of these resolves to the same IP.
>> And that IP address is probably a load balancer...  I'm pretty sure
>> that this single IP thing is not part of the performance measures.
>> Traian wrote:
>>> But then I decided that this can be worked around by using a file
>>> system mount from the web server to the server where the tiles are.
>>> I've seen a similar thing done on Linux/Apache, not sure if Windows
>>> could handle such a setup.
>> I've done this with IIS (CIFS share) and, while I can confirm that it
>> works, it's a pain to set up and the performance is very poor
>> compared to local filesystem access.
>> While this might be a good solution for some situations (like, where
>> the tile servers are behind a firewall?), I think that it would be
>> best to also have the option of being able to set up a local
>> webserver on the tile servers to serve the tiles directly to the
>> clients rather than having to do everything through the web tier server.
>> Jason
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Guestion-about-speedup-mapguide%2C-diferent-doma
> inname
> -to-mapagent.fcgi.-tf3307731s16610.html#a9242845
> Sent from the MapGuide Users mailing list archive at Nabble.com.
http://www.nabble.com/Guestion-about-speedup-mapguide%2C-diferent-domainname
-to-mapagent.fcgi.-tf3307731s16610.html#a9243904
