[mapguide-users] RE: RE: Guestion about speedup mapguide,
diferent domainname to mapagent.fcgi.
Kencana
bluesky_dyx at hotmail.com
Wed Feb 28 23:42:22 EST 2007
Hi Jonathon,
thanks for the feedback. I am using sdf file for the source. well it is
actually from shp file and mapguide studio
convert it to sdf file. as for the tooltip, it is one of the compulsory
thing so i guess i need to use it.
Thanks
Regards,
Kencana
Jonathon-12 wrote:
> Hi Kencana,
> I had a look at your site and agree that the performance is a lacking. I
> also don't know what your source is (SHP etc) but I have definitely found
> that the attributes attached make a huge difference (I started stripping
> out
> any data-it goes into a SQL Server database that I index as much as I can-
> in my shape dbfs that I don't use for tooltips and it helps a lot). I
> also
> use tooltips and labels as sparingly as possible (if you can, allow the
> user
> to select the item to get attribute info). It seems that there is a lot
> of
> information showing in the initial map view...can you remove some of the
> layers or thin the data, this helps.
> Hope that some of this might help...
> Cheers,
> Jonathon
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kencana
> Sent: Wednesday, February 28, 2007 6:44 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: Guestion about speedup mapguide, diferent
> Hi,
> the following is the url of my map. you can see that the map loading is
> very
> slow.
> by the way i am not using map tiled as because the map tiled initial view
> took longer time than the other one.
> any idea of improving it?
> http://202.172.177.8/mapguide/mapviewerajax/?WEBLAYOUT=Library://Web/YP%20SG
> %20Trial.WebLayout&LOCALE=en
> Thank you very much
> Regards,
> Kencana
> JasonBirch wrote:
>> Paul wrote:
>>> m1.google.com
>>> m2.google.com
>>> m3.google.com
>>> and that each of these resolves to the same IP.
>> And that IP address is probably a load balancer... I'm pretty sure
>> that this single IP thing is not part of the performance measures.
>> Traian wrote:
>>> But then I decided that this can be worked around by using a file
>>> system mount from the web server to the server where the tiles are.
>>> I've seen a similar thing done on Linux/Apache, not sure if Windows
>>> could handle such a setup.
>> I've done this with IIS (CIFS share) and, while I can confirm that it
>> works, it's a pain to set up and the performance is very poor compared
>> to local filesystem access.
>> While this might be a good solution for some situations (like, where
>> the tile servers are behind a firewall?), I think that it would be
>> best to also have the option of being able to set up a local webserver
>> on the tile servers to serve the tiles directly to the clients rather
>> than having to do everything through the web tier server.
>> Jason
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Guestion-about-speedup-mapguide%2C-diferent-domainname
> -to-mapagent.fcgi.-tf3307731s16610.html#a9242845
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/Guestion-about-speedup-mapguide%2C-diferent-domainname-to-mapagent.fcgi.-tf3307731s16610.html#a9243904
