[mapguide-users] DWF Plotting
    Knight, Gregory
    Gregory.Knight.bra at cityofboston.gov
    Fri Jan 12 10:35:27 EST 2007
Hi all,
I am working with the DWF plotting example (plot.aspx / plottask.aspx)
included with the Sheboygan dataset under MGOS 1.0.x.
First, the sample uses "6.01" and "1.2" respectively for the DWF file
version and schema.  My clients have the 7.0 (patched) DWF client.  Can
MGOS write to DXF 7.x?  If so, how do I determine the proper file
version and schema to use?
Second, somewhere along the line, plotting to DWF broke for me.  Many
things have changed since I recall plotting to DWF successfully
including upgrading both Internet Explorer and the DWF client.  The
error I get is that the path to the DWF is not correct.  The browser
tries to write?/read? the file in ...Local Settings\Temporary Internet
Files\Content.IE5\filename.DWF.  The Content.IE5 directory doesn't exist
here however.
Any idea what might be happening here?
Greg
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070112/cdb73770/attachment.html
