[mapguide-users] RE: [Mapguide_users]
MGRenderingServiceQueryFeatures
Chris Claydon
chris.claydon at autodesk.com
Fri Jan 12 14:20:56 EST 2007
Hi Scott,
Your method for creating the polygon seems to be valid. I wrote the
following php script to test it out. It uses QueryFeatures to retrieve a
feature set containing the IDs of all of the features in the Hydrography
layer within the specified polygon.
Important: Internally, the server performs a selection of all features
within the polygon, and then returns their IDs. Thus, it only works on
layers that are selectable. I had to modify the Sheboygan map definition
to make the Hydrography features selectable, otherwise I received an
empty feature set.
Chris.
(To test this code, save it to a php file in the mapviewerphp folder of
the web tier.)
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<title>PHP Test Page</title>
</head>
<body>
<?php
include 'constants.php';
try
$thisFile = __FILE__;
$pos = strrpos($thisFile, '\\');
if ($pos == false)
$pos = strrpos($thisFile, '/');
$configFilePath = substr($thisFile, 0,
$pos+1) . "../webconfig.ini";
MgInitializeWebTier ($configFilePath);
$userInfo = new
MgUserInformation("Administrator","admin");
$siteConn = new MgSiteConnection();
$siteConn->Open($userInfo);
$site = new MgSite();
$site->Open($userInfo);
$sessionId = $site->CreateSession();
$userInfo->SetMgSessionId($sessionId);
$renderingSrvc =
$siteConn->CreateService(MgServiceType::RenderingService);
$resourceSrvc =
$siteConn->CreateService(MgServiceType::ResourceService);
$mapId = new
MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefi
nition");
$map = new MgMap();
$map->Create($resourceSrvc, $mapId, "My Test Map");
//$geomWkt = "POLYGON((13383.143956941916
5108123.520005487, 41288.72069078572 5108123.520005487,
41288.72069078572 5091167.27038247, 13383.143956941916 5091167.27038247,
13383.143956941916 5108123.520005487))";
$geomWkt = "POLYGON((-180 -90, -180 90, 180 90, 180 -90,
-180 -90))";
$wktReader = new MgWktReaderWriter();
$geometry = $wktReader->Read($geomWkt);
$layers = new MgStringCollection();
$layers->Add("Hydrography");
$featureInfo = $renderingSrvc->QueryFeatures($map,
$layers, $geometry, MgFeatureSpatialOperations::Intersects, -1);
print($featureInfo->ToXml()->ToString());
catch (MgException $e)
echo $e->GetMessage();
</body>
</html>
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Scott
Hameister
Sent: January 12, 2007 9:59 AM
To: Mapguide_users at lists.osgeo.org
Subject: [mapguide-users] RE: [Mapguide_users]
PLEEEEEEEASE....
I'm going to reword this hoping it sparks some interest....
I have a Geometry Variable (geom) equal to:
POLYGON((13383.143956941916 5108123.520005487, 41288.72069078572
5108123.520005487, 41288.72069078572 5091167.27038247,
13383.143956941916
5091167.27038247, 13383.143956941916 5108123.520005487))
I need to get it into the proper format (MgGeometry) for this call:
RenderingService.QueryFeatures( MgMap map, MgStringCollection
layerNames,
>>MgGeometry<< geometry, int selectionVariant, int maxfeatures)
I'm using:
"MgWktReaderWriter" to send the variable into the RenderingService
using:
GeometryFromWkt = MgWktReaderWriter.Read(geom)
It creates an MgPolygon Object...But the QueryFeatures function won't
run....Is this the wrong Geometry type or the wrong geometry level?
I checked with GeometryFromWkt.IsValid() and it responds Yes?
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
