[mapguide-users] .Net Viewer seems to bomb on Measure
Chris Gountanis
cgountanis at mpower-tech.com
Tue Jan 16 15:32:40 EST 2007
Type 'OSGeo.MapGuide.MgResourceNotFoundException' in Assembly
'MapGuideDotNetApi, Version=1.0.0.17864, Culture=neutral,
PublicKeyToken=null' is not marked as serializable.
Seems when you open the viewer from the WebLayout preview area the measure
works but if you open the site inside frames using the /mapguide/ virtual
directory only errors. Will this be fixed soon or is there a work around? I
am doing my best to not change the viewer code if at all possible.
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070116/07b1e925/attachment-0001.html
