[mapguide-users] .Net Viewer seems to bomb on Measure
Chris Gountanis
cgountanis at mpower-tech.com
Tue Jan 16 16:00:37 EST 2007
Running buffers same error:
Type 'OSGeo.MapGuide.MgAuthenticationFailedException' in Assembly
'MapGuideDotNetApi, Version=1.0.0.17864, Culture=neutral,
PublicKeyToken=null' is not marked as serializable.
Has anyone got the viewer embedded using an iframe or fame set and got those
tools to work.
Chris
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Gountanis
Sent: Tuesday, January 16, 2007 2:33 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] .Net Viewer seems to bomb on Measure
Type 'OSGeo.MapGuide.MgResourceNotFoundException' in Assembly
Seems when you open the viewer from the WebLayout preview area the measure
works but if you open the site inside frames using the /mapguide/ virtual
directory only errors. Will this be fixed soon or is there a work around? I
am doing my best to not change the viewer code if at all possible.
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070116/198d7888/attachment.html
