[mapguide-users] .Net Viewer seems to bomb on Measure
Chris Gountanis cgountanis at mpower-tech.com
Wed Jan 17 09:42:06 EST 2007
OK, I did fix this. It had nothing to do with the viewer but more of an IIS
application/.net goof. I uninstalled the Web Extensions and removed all
virtual IIS directories. Reinstalled the Web Extensions with SP1
(Enterprise). Then recreated the web shares (virtual directories) and
everything seems fixed. It's magical!
Case Closed. It was on my end but if you run into this that might help you
as well.
Chris
  _____
From: Chris Gountanis [mailto:cgountanis at mpower-tech.com]
Sent: Tuesday, January 16, 2007 3:01 PM
To: 'Chris Gountanis'; mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] .Net Viewer seems to bomb on Measure
Running buffers same error:
Type 'OSGeo.MapGuide.MgAuthenticationFailedException' in Assembly
'MapGuideDotNetApi, Version=1.0.0.17864, Culture=neutral,
PublicKeyToken=null' is not marked as serializable.
Has anyone got the viewer embedded using an iframe or fame set and got those
tools to work.
Chris
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Gountanis
Sent: Tuesday, January 16, 2007 2:33 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] .Net Viewer seems to bomb on Measure
Type 'OSGeo.MapGuide.MgResourceNotFoundException' in Assembly
Seems when you open the viewer from the WebLayout preview area the measure
works but if you open the site inside frames using the /mapguide/ virtual
directory only errors. Will this be fixed soon or is there a work around? I
am doing my best to not change the viewer code if at all possible.
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070117/eda71482/attachment-0001.html
