[mapguide-users] How to delete temporary layer from user session - or how to reload 1 added point whit definition in xml.
Maciej Skorczewski maciej.skorczewski at procad.pl
Tue Jan 23 08:46:18 EST 2007
Hi all!
My problem is strange so i write small 	introduction.
I make it whit  this steps.
1 STEP. I Get points who are stored in database (user can add new points
on map who after moderate are showed on map).
2 STEP. I add point to map by use:
$geometryFactory = new MgGeometryFactory();
$coordinate = $geometryFactory->CreateCoordinateXY($x,$y);
$point = $geometryFactory->CreatePoint($coordinate);
...definition of points (symbols,x,y,image of object) are stored in XML
file (who is loaded by
  function CreateParcelMarkerLayer($resourceService,
$parcelMarkerDataResId, $sessionId))
one XML file is generate whit rules of each points who are stored in
database.
3 STEP. I add this points to map (execute my script)
so i get
a) layer is created- and added to layerpane - OK!
b) points are on the map - every have different icon and size.- OK!
BUT when i edit point i change it: (Rotation or X,Y - size in Meters)
THE PROBLEM IS HOW CAN I RELOAD ONLY ONE POINT WHO EDITED WAS?
What i make now;
1. i can delete this point
2. i add new point in this same place - BUT IT have this same definition
of deleted point - so when i add changes (i generate new xml file whit
definition of points) ex. it have another Rotation lebel... the new
points have old gefinition
What can help me:
1. how to delete from curent user session layer whit ceated points - now
i can only hidden only by
  $parcelMarkerLayer->SetDisplayInLegend(false);
  $parcelMarkerLayer->SetSelectable(false);
2. after dalete it - i must reload in again (whit new XML definition of
each points) - it should by named this same.
Any sugestion?
Maciek
