[mapguide-users] RE: MySQL FDO not working in Studio
Dave Wilson
dave.wilson at autodesk.com
Tue Jan 23 11:43:40 EST 2007
The libmysql.dll isn't needed by Studio, it is needed by the server. You can either modify your system path to include the mysql directory containing the dll or copy the dll to the FDO folder under the server install. This is only required on Windows.
Give that a try.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Tuesday, January 23, 2007 8:55 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] RE: MySQL FDO not working in Studio
This looks like the same problem with ARCSDE FDO the names of the dlls changed between releases and now the fdo won't work.
Not certain, but it is a possibility.
Brad
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Adrià
Sent: Tuesday, January 23, 2007 8:47 AM
Subject: [mapguide-users] RE: MySQL FDO not working in Studio
I haven't found any mysql.dll library in the MySQL 5 directory. Did you mean libMySQL.dll? Anyway, I copied it into the FDO and it had no effect. I get the same empty warnings in Studio.
Any other ideas?
Thanks
Deepak Kumar wrote:
> Hi
> This issue is due to incompatible mysql.dll file.
> You find mysql.dll from your MySQL 5 directory and copy it to the fdo
> directory.
> Regards
> Deepak Kumar
> http://www.roseindia.net
> [mailto:mapguide-users-bounces at lists.osgeo.org]On Behalf Of Adrià
> Sent: Tuesday, January 23, 2007 4:05 PM
> Subject: [mapguide-users] MySQL FDO not working in Studio
> Hi,
> I'm sorry if this has already been answered, I searched the list and
> found some people with similar problems, but none of the solutions
> proposed worked for me.
> I'm trying to connect to a MySQL database from Autodesk MapGuide
> Studio
> 2007
> through the FDO (v 3.1.0.0). I have MySQL Server 5.0 freshly installed
> and running on localhost, but when trying to test the connection, the
> program returns a warning sign with no message. Similarly, when
> choosing a data store, an empty warning is displayed, followed by a "No data stores found"
> message.
> Any ideas? Thanks for your help
> Details:
> ·OS: Windows XP SP2
> ·Map Guide Server v 1.0.2
> ·MySQL 5.0.27-community-nt
> ·Autodesk MapGuide Studio 2007
> ·OSGeo FDO Provider for MySQL v3.1.0.0
http://www.nabble.com/MySQL-FDO-not-working-in-Studio-tf3063314s16610.html#a
8519096
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
8522968
