[mapguide-users] 1.1.0 and WFS?
Andy Morsell
amorsell at spatialgis.com
Thu Jan 25 12:52:22 EST 2007
Autodesk, can you confirm that you can successfully test WFS on a default
1.1.0 Windows install via the following URL?
http://servername/mapguide/mapagent/mapagent.fcgi?request=getCapabilities&se
rvice=wfs&version=1.0.0
Andy
-----Original Message-----
Sent: Thursday, January 25, 2007 9:41 AM
To: Andy Morsell
Subject: RE: [mapguide-users] 1.1.0 and WFS?
The problem doesn't seem to be a dependency problem.
The "Provider Not Registered" message means that the provider name is not
found in the providers.xml file.
Are you sure you are looking at the correct providers.xml file?
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: January 25, 2007 12:25 PM
To: mapguide-users at lists.osgeo.org
I installed Dependency Walker on that server and while it appears that no
dll's are missing, the link checksums are shown as incorrect for FDO.dll,
FDOCommon.dll, FDOGeometry.dll, FDOSpatial.dll, OWS.dll. Other than this,
I'm not really sure how to interpret the results. Do you recommend a
different dependency checking utility?
Thanks.
Andy
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Thursday, January 25, 2007 9:06 AM
To: Andy Morsell; mapguide-users at lists.osgeo.org
Oh sorry, I didn't read all the way. Did you check the dll dependencies
for
something missing?
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Thursday, January 25, 2007 11:47 AM
To: Traian Stanev; mapguide-users at lists.osgeo.org
This message lost some of it's original context.... In the original
message
yesterday, I had mentioned that there is an entry for
OSGeo.WFS.3.2 in providers.xml and it is shown when I do a
GetFeatureProviders operation on the mapagent.
Thanks.
Andy
Sent: Thursday, January 25, 2007 8:37 AM
Check if there is an entry for the provider in the providers.xml file.
FDO providers aren't COM so there is no need to register them with
regsvr.
"Registration" means adding an entry for the provider to that xml file.
Traian
Morsell
Sent: Thursday, January 25, 2007 11:12 AM
Subject: Re: [mapguide-users] 1.1.0 and WFS?
Hi James,
Yes, I had actually tried that (but failed to mention it). When I do
that,
it returns "WMSProvider.dll was loaded, but the DllRegisterServer entry
point was not found"
Andy
Sent: Thursday, January 25, 2007 7:41 AM
To: Andy Morsell
Subject: SPAM-LOW: Re: [mapguide-users] 1.1.0 and WFS?
On Wed, 24 Jan 2007 16:05:10 -0800, Andy Morsell
<amorsell at spatialgis.com>
wrote:
> An exception occurred in FDO component. FDO Provider Not Registered
> Exception occurred in method MgFdoConnectionManager.Open at line 200
> in I've confirmed that providers.xml does have an entry for
OSGeo.WFS.3.2.
> The Server/Bin/FDO folder does contain WFSProvider.dll.
I haven't tried installing 1.1.0 yet, but that error message would
prompt me
to run "regsvr32.exe WFSProvider.dll" to see if that would resolve the
problem.
James Card
California CAD Solutions, Inc.
209 578-5580
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
