[mapguide-users] 1.1.0 and WFS?
Tom Fukushima tom.fukushima at autodesk.com
Thu Jan 25 13:06:12 EST 2007
Hi Andy,
This worked for me.
I had a default Apache install on a clean XP VMWare image.  I installed
the Sheboygan samples, and did the request you did below. And it came
back with what looks to be a good capabilities document.
Tom
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Thursday, January 25, 2007 10:52 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] 1.1.0 and WFS?
Autodesk, can you confirm that you can successfully test WFS on a
default 1.1.0 Windows install via the following URL?
http://servername/mapguide/mapagent/mapagent.fcgi?request=getCapabilitie
s&se
rvice=wfs&version=1.0.0
Andy
Sent: Thursday, January 25, 2007 9:41 AM
To: Andy Morsell
The problem doesn't seem to be a dependency problem.
The "Provider Not Registered" message means that the provider name is
not found in the providers.xml file.
Are you sure you are looking at the correct providers.xml file?
Morsell
Sent: January 25, 2007 12:25 PM
I installed Dependency Walker on that server and while it appears that
no dll's are missing, the link checksums are shown as incorrect for
FDO.dll, FDOCommon.dll, FDOGeometry.dll, FDOSpatial.dll, OWS.dll.  Other
than this, I'm not really sure how to interpret the results.  Do you
recommend a different dependency checking utility?
Thanks.
Andy
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Thursday, January 25, 2007 9:06 AM
To: Andy Morsell; mapguide-users at lists.osgeo.org
Oh sorry, I didn't read all the way. Did you check the dll dependencies
for something missing?
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Thursday, January 25, 2007 11:47 AM
To: Traian Stanev; mapguide-users at lists.osgeo.org
This message lost some of it's original context.... In the original
message yesterday, I had mentioned that there is an entry for
OSGeo.WFS.3.2 in providers.xml and it is shown when I do a
GetFeatureProviders operation on the mapagent.
Thanks.
Andy
Sent: Thursday, January 25, 2007 8:37 AM
Check if there is an entry for the provider in the providers.xml file.
FDO providers aren't COM so there is no need to register them with
regsvr.
"Registration" means adding an entry for the provider to that xml file.
Traian
Morsell
Sent: Thursday, January 25, 2007 11:12 AM
Subject: Re: [mapguide-users] 1.1.0 and WFS?
 Hi James,
Yes, I had actually tried that (but failed to mention it).  When I do
that, it returns "WMSProvider.dll was loaded, but the DllRegisterServer
entry point was not found"
Andy
Sent: Thursday, January 25, 2007 7:41 AM
To: Andy Morsell
Subject: SPAM-LOW: Re: [mapguide-users] 1.1.0 and WFS?
On Wed, 24 Jan 2007 16:05:10 -0800, Andy Morsell
<amorsell at spatialgis.com>
wrote:
> An exception occurred in FDO component. FDO Provider Not Registered
> Exception occurred in method MgFdoConnectionManager.Open at line 200
> in I've confirmed that providers.xml does have an entry for
OSGeo.WFS.3.2.
> The Server/Bin/FDO folder does contain WFSProvider.dll.
I haven't tried installing 1.1.0 yet, but that error message would
prompt me to run "regsvr32.exe WFSProvider.dll" to see if that would
resolve the problem.
James Card
California CAD Solutions, Inc.
209 578-5580
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
