[mapguide-users] 1.1.0 and WFS?
Andy Morsell amorsell at spatialgis.com
Thu Jan 25 14:35:48 EST 2007
Yup, I checked both and nothing.  I also uninstalled and reinstalled Server
with no change.
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Thursday, January 25, 2007 10:59 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] 1.1.0 and WFS?
Check your path and entire environment for references to FDO?
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Thursday, January 25, 2007 10:54
To: 'Tom Fukushima'; mapguide-users at lists.osgeo.org
Tom,
This particular installation is on my production server that previously had
MGOS 1.0.1 installed.  I had uninstalled it and deleted the
MapGuideOpenSource folder.  I then pointed my repository folders to my
repository maintained outside of the MapGuide folder via admin.  There are
no other FDO applications on that machine.  My installation in this
particular case is Windows 2000 Server on IIS with the .NET web extensions.
It does seem like I am having a .dll conflict of some sort.  Would the
build_3.1 reference in the below error be indicative of some sort of
conflict with an older FDO 3.1 component?
An exception occurred in FDO component. FDO Provider Not Registered An
exception occurred in FDO component. FDO Provider Not Registered Exception
occurred in method MgFdoConnectionManager.Open at line 200 in file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\commo
n\ma
nager\FdoConnectionManager.cpp
I'm at a bit of a loss at this point.
Andy
From: Tom Fukushima [mailto:tom.fukushima at autodesk.com]
Sent: Thursday, January 25, 2007 10:06 AM
To: Andy Morsell; mapguide-users at lists.osgeo.org
Hi Andy,
This worked for me.
I had a default Apache install on a clean XP VMWare image.  I installed the
Sheboygan samples, and did the request you did below. And it came back with
what looks to be a good capabilities document.
Tom
Sent: Thursday, January 25, 2007 10:52 AM
Autodesk, can you confirm that you can successfully test WFS on a default
1.1.0 Windows install via the following URL?
http://servername/mapguide/mapagent/mapagent.fcgi?request=getCapabilitie
s&se
rvice=wfs&version=1.0.0
Andy
Sent: Thursday, January 25, 2007 9:41 AM
To: Andy Morsell
The problem doesn't seem to be a dependency problem.
The "Provider Not Registered" message means that the provider name is not
found in the providers.xml file.
Are you sure you are looking at the correct providers.xml file?
Sent: January 25, 2007 12:25 PM
I installed Dependency Walker on that server and while it appears that no
dll's are missing, the link checksums are shown as incorrect for FDO.dll,
FDOCommon.dll, FDOGeometry.dll, FDOSpatial.dll, OWS.dll.  Other than this,
I'm not really sure how to interpret the results.  Do you recommend a
different dependency checking utility?
Thanks.
Andy
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Thursday, January 25, 2007 9:06 AM
Oh sorry, I didn't read all the way. Did you check the dll dependencies for
something missing?
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Thursday, January 25, 2007 11:47 AM
To: Traian Stanev; mapguide-users at lists.osgeo.org
This message lost some of it's original context.... In the original message
yesterday, I had mentioned that there is an entry for
OSGeo.WFS.3.2 in providers.xml and it is shown when I do a
GetFeatureProviders operation on the mapagent.
Thanks.
Andy
Sent: Thursday, January 25, 2007 8:37 AM
Check if there is an entry for the provider in the providers.xml file.
FDO providers aren't COM so there is no need to register them with regsvr.
"Registration" means adding an entry for the provider to that xml file.
Traian
Sent: Thursday, January 25, 2007 11:12 AM
Subject: Re: [mapguide-users] 1.1.0 and WFS?
 Hi James,
Yes, I had actually tried that (but failed to mention it).  When I do that,
it returns "WMSProvider.dll was loaded, but the DllRegisterServer entry
point was not found"
Andy
Sent: Thursday, January 25, 2007 7:41 AM
To: Andy Morsell
Subject: SPAM-LOW: Re: [mapguide-users] 1.1.0 and WFS?
On Wed, 24 Jan 2007 16:05:10 -0800, Andy Morsell <amorsell at spatialgis.com>
> Exception occurred in method MgFdoConnectionManager.Open at line 200
> in I've confirmed that providers.xml does have an entry for
OSGeo.WFS.3.2.
> The Server/Bin/FDO folder does contain WFSProvider.dll.
I haven't tried installing 1.1.0 yet, but that error message would prompt me
to run "regsvr32.exe WFSProvider.dll" to see if that would resolve the
problem.
James Card
California CAD Solutions, Inc.
209 578-5580
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
