[mapguide-users] 1.1.0 and WFS?
Tom Fukushima
tom.fukushima at autodesk.com
Thu Jan 25 14:45:49 EST 2007
Hi Andy,
The 3.1 that you are seeing is the build number of the MGOS 1.1.0 build
and is not related to FDO.
The FDO Provider not registered exception is not necessarily the WFS
provider that is not registered; using MGOS 1.1.0 as a WFS service does
not require the WFS FDO provider to be installed. However, I was able
to get the error you are seeing if I remove the SDF provider. Perhaps,
you have OGR or Autodesk Raster or ... feature sources that are
published.
Tom
-----Original Message-----
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Thursday, January 25, 2007 11:54 AM
To: Tom Fukushima; mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] 1.1.0 and WFS?
Tom,
This particular installation is on my production server that previously
had MGOS 1.0.1 installed. I had uninstalled it and deleted the
MapGuideOpenSource folder. I then pointed my repository folders to my
repository maintained outside of the MapGuide folder via admin. There
are no other FDO applications on that machine. My installation in this
particular case is Windows 2000 Server on IIS with the .NET web
extensions.
It does seem like I am having a .dll conflict of some sort. Would the
build_3.1 reference in the below error be indicative of some sort of
conflict with an older FDO 3.1 component?
An exception occurred in FDO component. FDO Provider Not Registered An
Exception occurred in method MgFdoConnectionManager.Open at line 200 in
file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\commo
n\ma
nager\FdoConnectionManager.cpp
I'm at a bit of a loss at this point.
Andy
