[mapguide-users] 1.1.0 and WFS?
Andy Morsell
amorsell at spatialgis.com
Thu Jan 25 14:58:20 EST 2007
Good detective work Tom. That was it. I removed all of my raster data
source references in the repository which had previously used the Autodesk
raster provider. Apparently, when the WFS GetCapabilities request
enumerates all of the site data sources to see if they are published to WFS,
it chokes on ones that reference a non-installed FDO provider.
Thanks for all of your help.
Andy
-----Original Message-----
From: Tom Fukushima [mailto:tom.fukushima at autodesk.com]
Sent: Thursday, January 25, 2007 11:46 AM
To: Andy Morsell; mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] 1.1.0 and WFS?
Hi Andy,
The 3.1 that you are seeing is the build number of the MGOS 1.1.0 build and
is not related to FDO.
The FDO Provider not registered exception is not necessarily the WFS
provider that is not registered; using MGOS 1.1.0 as a WFS service does not
require the WFS FDO provider to be installed. However, I was able to get
the error you are seeing if I remove the SDF provider. Perhaps, you have
OGR or Autodesk Raster or ... feature sources that are published.
Tom
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Thursday, January 25, 2007 11:54 AM
To: Tom Fukushima; mapguide-users at lists.osgeo.org
Tom,
This particular installation is on my production server that previously had
MGOS 1.0.1 installed. I had uninstalled it and deleted the
MapGuideOpenSource folder. I then pointed my repository folders to my
repository maintained outside of the MapGuide folder via admin. There are
no other FDO applications on that machine. My installation in this
particular case is Windows 2000 Server on IIS with the .NET web extensions.
It does seem like I am having a .dll conflict of some sort. Would the
build_3.1 reference in the below error be indicative of some sort of
conflict with an older FDO 3.1 component?
An exception occurred in FDO component. FDO Provider Not Registered An
exception occurred in FDO component. FDO Provider Not Registered Exception
occurred in method MgFdoConnectionManager.Open at line 200 in file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\commo
n\ma
nager\FdoConnectionManager.cpp
I'm at a bit of a loss at this point.
Andy
