[mapguide-users] Preliminary MrSID and ECW Support
Chris Tallman
ctallman at innomap.com
Mon Jan 29 08:37:38 EST 2007
Frank,
Great job seems to work pretty good. Very fast loading a 93+MB image.
I am having one problem and I'm not sure if I missed something or if
it's an error. I have my data connected to a folder containing multiple
MrSid files. Only the first image alphabetically displays on the map.
Have I missed a step is anyone else seeing this behavior? Also does the
aerial need to be on the local system, I can't seem to get the image to
display if I map to a network folder.
Again great job.
Chris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nichols,
Mark A.
Sent: Sunday, January 28, 2007 3:07 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Preliminary MrSID and ECW Support
Frank, I can look into this but it may not be until Monday morning. I
have 15 GB of ecw imagery that I'm hopeful to use with MapGuide. This
would be a huge improvement!
Mark Nichols
markn at spicergroup.com
From: mapguide-users-bounces at lists.osgeo.org on behalf of Frank
Warmerdam
Sent: Sun 1/28/2007 1:41 AM
Subject: [mapguide-users] Preliminary MrSID and ECW Support
Folks,
I have spent some time in "windows land" and I seem to have support
for ECW and MrSID working in MapGuide. But I'd appreciate it if
someone could try these out and verify.
The updates are at:
http://www.gdal.org/dl/mapguide/mg_ecw_110.zip
http://www.gdal.org/dl/mapguide/mg_mrsid_110.zip
Either zip file (or both) can be downloaded, and unzipped
into your C:\Program Files\MapGuideOpenSource\Server\Bin directory.
They should create a gdalplugins subdirectory to bin with a plugin.
They
will also replace the FDO\GRFPProvider.dll with a new version that uses
the FDO\gdal13.dll instead of statically linking an extra copy of GDAL
into the GRFPProvider.dll. The MrSID verison also includes an updated
gdal13.dll because the stock one does not export certain geotiff related
interfaces used by the mrsid driver.
There should be no need to set any extra environment variables or
anything like that. The plugins should be found magically because they
are in the gdalplugins subdirectory under the executable (MgServer.exe).
There are licensing terms associated with the ecw and mrsid sdks which
I have not taken the time yet to summarize inside the downloads. If we
prove this works from a technology point of view we can see how we want
to address the licensing.
BTW, the brief version of the procedure to add a mrsid or ecw to your
map is:
o Create a new "data connection" using the OSGeo data provider.
o Set the DefaultRasterLocation property to the directory containing
the desired raster files (or perhaps directly to a single file if
that is all you want).
o Save the Data connection object.
o Create a layer, and connect.
o Create a map and connect. You will have to set the map bounds
manually as the bounds aren't currently read from the datasource.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGeo,
http://osgeo.org
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070129/b76bf13d/attachment.html
