[mapguide-users] Preliminary MrSID and ECW Support
Nichols, Mark A.
markn at spicergroup.com
Mon Jan 29 12:42:27 EST 2007
If I'm reading this post correctly, I am also seeing issues with
multiple raster files in a single folder. Yes, I'm seeing all the
rasters within a folder on the map. Try making separate folders with
only one raster in each. This worked for me.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Tallman
Sent: Monday, January 29, 2007 11:58 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Preliminary MrSID and ECW Support
Jason,
Thanks that did the trick I changed the account to a network account and
now I can access the network share. However I'm still only seeing the
first aerial in the list.
Any ideas on this? Are you seeing all the images in your folder, on
your map?
Chris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, January 29, 2007 11:39 AM
Chris,
Is the MapGuide service running under a local account? I haven't run
into this yet, but I've seen this kind of problem with other services
not being able to access network resource. You typically have to run
them under a network account, or have an account on both machines with
synced passwords.
Jason
Tallman
Sent: Monday, January 29, 2007 05:38
Frank,
Great job seems to work pretty good. Very fast loading a 93+MB image.
I am having one problem and I'm not sure if I missed something or if
it's an error. I have my data connected to a folder containing multiple
MrSid files. Only the first image alphabetically displays on the map.
Have I missed a step is anyone else seeing this behavior? Also does the
aerial need to be on the local system, I can't seem to get the image to
display if I map to a network folder.
Again great job.
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070129/2d25bb5b/attachment.html
