[mapguide-users] Preliminary MrSID and ECW Support
Andy Morsell
amorsell at spatialgis.com
Mon Jan 29 13:22:09 EST 2007
In your data connection configuration in Studio, can you explicitly define
one image for one data connection and another image for a different data
connection definition? That's currently how I'm doing it with a folder that
contains a mix of TIF, SID and ECW.
Andy
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Tallman
Sent: Monday, January 29, 2007 8:58 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Preliminary MrSID and ECW Support
Jason,
Thanks that did the trick I changed the account to a network account and now
I can access the network share. However I'm still only seeing the first
aerial in the list.
Any ideas on this? Are you seeing all the images in your folder, on your
map?
Chris
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, January 29, 2007 11:39 AM
Chris,
Is the MapGuide service running under a local account? I haven't run into
this yet, but I've seen this kind of problem with other services not being
able to access network resource. You typically have to run them under a
network account, or have an account on both machines with synced passwords.
Jason
_____
Sent: Monday, January 29, 2007 05:38
Frank,
Great job seems to work pretty good. Very fast loading a 93+MB image.
I am having one problem and I'm not sure if I missed something or if it's an
error. I have my data connected to a folder containing multiple MrSid
files. Only the first image alphabetically displays on the map. Have I
missed a step is anyone else seeing this behavior? Also does the aerial
need to be on the local system, I can't seem to get the image to display if
I map to a network folder.
Again great job.
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070129/13e4f62d/attachment-0001.html
