[mapguide-users] Preliminary MrSID and ECW Support
Chris Tallman
ctallman at innomap.com
Mon Jan 29 13:51:08 EST 2007
I've gotten that to work fine. Unless I read incorrectly you should be
able to define a folder and all the images in that folder will be
mapped. Maybe I'm wrong. However when I map a folder in this matter
only the first images is displayed.
I guess I was thinking that if I had a folder full of tiles say 200, and
I mapped the folder all the tiles would be displayed in the map without
having to explicitly define a data connection to each image. Maybe this
isn't enabled in the new plug-ins that Frank just finished, I just
wanted to see if anyone else was seeing the behavior and if not maybe I
missed something.
Anyway as I stated earlier great job Frank this driver is very fast and
shows the images very quickly. This is a great addition to the MGOS
app.
Chris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Monday, January 29, 2007 1:22 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Preliminary MrSID and ECW Support
In your data connection configuration in Studio, can you explicitly
define one image for one data connection and another image for a
different data connection definition? That's currently how I'm doing it
with a folder that contains a mix of TIF, SID and ECW.
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Tallman
Sent: Monday, January 29, 2007 8:58 AM
To: MapGuide Users Mail List
Jason,
Thanks that did the trick I changed the account to a network account and
now I can access the network share. However I'm still only seeing the
first aerial in the list.
Any ideas on this? Are you seeing all the images in your folder, on
your map?
Chris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, January 29, 2007 11:39 AM
Chris,
Is the MapGuide service running under a local account? I haven't run
into this yet, but I've seen this kind of problem with other services
not being able to access network resource. You typically have to run
them under a network account, or have an account on both machines with
synced passwords.
Jason
Tallman
Sent: Monday, January 29, 2007 05:38
Frank,
Great job seems to work pretty good. Very fast loading a 93+MB image.
I am having one problem and I'm not sure if I missed something or if
it's an error. I have my data connected to a folder containing multiple
MrSid files. Only the first image alphabetically displays on the map.
Have I missed a step is anyone else seeing this behavior? Also does the
aerial need to be on the local system, I can't seem to get the image to
display if I map to a network folder.
Again great job.
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070129/47dcbd64/attachment.html
