[mapguide-users] web studio - feature data setup?
Zak James
zak4ms at gmail.com
Mon Jan 29 22:59:30 EST 2007
Tim,
It's possible that something specific to IIS is going wrong, but if
that was the case I would expect the sdf/shp in the repository to be
damaged in some way. Can you grab a shape file from the repository and
try to load it with another tool to make sure it's still valid?
If that looks ok, I'd be interested in seeing the xml for the feature
source (you can save it using Studio or the mapagent utility.)
zak
On 1/29/07, TW <twiebe at cityofwinkler.ca> wrote:
> Zak,
> Yes, the sdf file and shp files are in the library respository folder on the
> server.
> However web studio will not allow me to create an unmanaged feature source.
> Any suggestions? Is there more setting up to do with IIS?
> Zak James wrote:
> > Tim,
> > Can you search through the repository to see if the sdf file is
> > actually present on the server? I'm wondering if there is some IIS
> > specific issue with the upload mechanism. It works under apache.
> > Another thing you could try is creating an unmanaged feature source
> > (pointing it to a file/folder already on the server) to see if that
> > allows you to create a layer.
> > zak
> > On 1/26/07, TW <twiebe at cityofwinkler.ca> wrote:
> >> When I try to create a layer from an uploaded data source in web studio
> >> it
> >> will not allow me to occupy the feature class or geometry fields to setup
> >> the layer.
> >> Web studio will allow me to create a feature data source and upload
> >> either a
> >> shp file or sdf, and yes it does actual create a folder in the
> >> respoistory
> >> and makes it available.
> >> I am running the server on IIS 5. Am I missing something obvious? I have
> >> used the enterprise software and it works fine. But I cannot use the
> >> Opensource.
> >> What am I missing?
> >> Tim
> >> View this message in context:
> >> http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8657214
> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> mapguide-users mailing list
> >> mapguide-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> > Zak James
> > Applications and Software Development
> > DM Solutions Group Inc.
> > http://www.dmsolutions.ca
> View this message in context: http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8690301
Zak James
