[mapguide-users] web studio - feature data setup?
TW twiebe at cityofwinkler.ca
Tue Jan 30 10:35:55 EST 2007
Zak
The uploaded file is not corrupt it still can be opened. Its almost as if
webstudio will not attempt to load the data source when creating the layer.
I noticed that when I select the data source, the animated icon on the
viewer frame doesn't do anything.
I know that when I initially load the webstudio I am getting some page
errors.
If you want me to submit the feature xml, you will have to explain where I
can get this  file for you. I am not sure I know where in the webstudio I
have to save this xml file.
Tim
Zak James wrote:
> Tim,
> It's possible that something specific to IIS is going wrong, but if
> that was the case I would expect the sdf/shp in the repository to be
> damaged in some way. Can you grab a shape file from the repository and
> try to load it with another tool to make sure it's still valid?
> If that looks ok, I'd be interested in seeing the xml for the feature
> source (you can save it using Studio or the mapagent utility.)
> zak
> On 1/29/07, TW <twiebe at cityofwinkler.ca> wrote:
>> Zak,
>> Yes, the sdf file and shp files are in the library respository folder on
>> the
>> server.
>> However web studio will not allow me to create an unmanaged feature
>> source.
>> Any suggestions? Is there more setting up to do with IIS?
>> Zak James wrote:
>> > Tim,
>> > Can you search through the repository to see if the sdf file is
>> > actually present on the server? I'm wondering if there is some IIS
>> > specific issue with the upload mechanism. It works under apache.
>> > Another thing you could try is creating an unmanaged feature source
>> > (pointing it to a file/folder already on the server) to see if that
>> > allows you to create a layer.
>> > zak
>> > On 1/26/07, TW <twiebe at cityofwinkler.ca> wrote:
>> >> When I try to create a layer from an uploaded data source in web
>> studio
>> >> it
>> >> will not allow me to occupy the feature class or geometry fields to
>> setup
>> >> the layer.
>> >> Web studio will allow me to create a feature data source and upload
>> >> either a
>> >> shp file or sdf, and yes it does actual create a folder in the
>> >> respoistory
>> >> and makes it available.
>> >> I am running the server on IIS 5. Am I missing something obvious? I
>> have
>> >> used the enterprise software and it works fine. But I cannot use the
>> >> Opensource.
>> >> What am I missing?
>> >> Tim
>> >> View this message in context:
>> http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8657214
>> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> >> _______________________________________________
>> >> mapguide-users mailing list
>> >> mapguide-users at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> > Zak James
>> > Applications and Software Development
>> > DM Solutions Group Inc.
>> > http://www.dmsolutions.ca
>> http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8690301
> Zak James
http://www.nabble.com/file/6112/error1.JPG error1.JPG
http://www.nabble.com/file/6113/error2.JPG error2.JPG
View this message in context: http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8709203
