[mapguide-users] web studio - feature data setup?
TW twiebe at cityofwinkler.ca
Wed Jan 31 16:49:17 EST 2007
Zak,
I tried editing the xml file with no success.
 What I did find was something that I should of seen before.
When I create a data featuresource in webstudio and upload the sdf
"test.sdf", it uploads and shows the file in data resource, but in the data
location field it only shows  %MG_DATA_FILE_PATH%
It should read, %MG_DATA_FILE_PATH%test.sdf
As before the file is in the library repository and is valid.
I am not sure what is causing this but I thought might have an idea
Tim
Zak James wrote:
> Tim,
> I looked into this a bit and it seems that I failed to make some
> necessary updates to webstudio prior to the MapGuide 1.1 release. The
> template for new feature sources has a hard coded value referencing a
> 3.0 fdo provider which isn't included in the new release and won't
> work with MapGuide 1.1.
> I will file a bug and patch this problem but in the longer term I'm
> planning to redesign how webstudio detects and uses providers to allow
> creation of additional feature sources.
> In the meantime, you can get SDF upload working by modifying the
> feature source template
> (WebServerExtensions/www/webstudio/templates/FeatureSource.xml in your
> mapguide installation), replacing 3.0 with 3.2.
> For SHP, the fix is a little more complicated and your best bet would
> be to use mapagent to modify the feature source once it has been
> created in the repository. You should then be able to use it to create
> layers in webstudio,
> zak
> On 1/29/07, Zak James <zak4ms at gmail.com> wrote:
>> Tim,
>> It's possible that something specific to IIS is going wrong, but if
>> that was the case I would expect the sdf/shp in the repository to be
>> damaged in some way. Can you grab a shape file from the repository and
>> try to load it with another tool to make sure it's still valid?
>> If that looks ok, I'd be interested in seeing the xml for the feature
>> source (you can save it using Studio or the mapagent utility.)
>> zak
>> On 1/29/07, TW <twiebe at cityofwinkler.ca> wrote:
>> > Zak,
>> > Yes, the sdf file and shp files are in the library respository folder
>> on the
>> > server.
>> > However web studio will not allow me to create an unmanaged feature
>> source.
>> > Any suggestions? Is there more setting up to do with IIS?
>> > Zak James wrote:
>> > > Tim,
>> > > Can you search through the repository to see if the sdf file is
>> > > actually present on the server? I'm wondering if there is some IIS
>> > > specific issue with the upload mechanism. It works under apache.
>> > > Another thing you could try is creating an unmanaged feature source
>> > > (pointing it to a file/folder already on the server) to see if that
>> > > allows you to create a layer.
>> > > zak
>> > > On 1/26/07, TW <twiebe at cityofwinkler.ca> wrote:
>> > >> When I try to create a layer from an uploaded data source in web
>> studio
>> > >> it
>> > >> will not allow me to occupy the feature class or geometry fields to
>> setup
>> > >> the layer.
>> > >> Web studio will allow me to create a feature data source and upload
>> > >> either a
>> > >> shp file or sdf, and yes it does actual create a folder in the
>> > >> respoistory
>> > >> and makes it available.
>> > >> I am running the server on IIS 5. Am I missing something obvious? I
>> have
>> > >> used the enterprise software and it works fine. But I cannot use the
>> > >> Opensource.
>> > >> What am I missing?
>> > >> Tim
>> > >> View this message in context:
>> http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8657214
>> > >> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> > >> _______________________________________________
>> > >> mapguide-users mailing list
>> > >> mapguide-users at lists.osgeo.org
>> > >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> > > Zak James
>> > > Applications and Software Development
>> > > DM Solutions Group Inc.
>> > > http://www.dmsolutions.ca
>> http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8690301
>> Zak James
> Zak James
View this message in context: http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8738428
