[mapguide-users] web studio - feature data setup?
TW twiebe at cityofwinkler.ca
Tue Jan 30 12:32:13 EST 2007
Thanks Zak,
I just wanted to note, that if I load the sheboygan project. Webstudio will
allow me to create new layers with the data provided in the sheboygan set.
I'll try your suggestion and let you know how it works out.
Thanks
Zak James wrote:
> Tim,
> I looked into this a bit and it seems that I failed to make some
> necessary updates to webstudio prior to the MapGuide 1.1 release. The
> template for new feature sources has a hard coded value referencing a
> 3.0 fdo provider which isn't included in the new release and won't
> work with MapGuide 1.1.
> I will file a bug and patch this problem but in the longer term I'm
> planning to redesign how webstudio detects and uses providers to allow
> creation of additional feature sources.
> In the meantime, you can get SDF upload working by modifying the
> feature source template
> (WebServerExtensions/www/webstudio/templates/FeatureSource.xml in your
> mapguide installation), replacing 3.0 with 3.2.
> For SHP, the fix is a little more complicated and your best bet would
> be to use mapagent to modify the feature source once it has been
> created in the repository. You should then be able to use it to create
> layers in webstudio,
> zak
> On 1/29/07, Zak James <zak4ms at gmail.com> wrote:
>> Tim,
>> It's possible that something specific to IIS is going wrong, but if
>> that was the case I would expect the sdf/shp in the repository to be
>> damaged in some way. Can you grab a shape file from the repository and
>> try to load it with another tool to make sure it's still valid?
>> If that looks ok, I'd be interested in seeing the xml for the feature
>> source (you can save it using Studio or the mapagent utility.)
>> zak
>> On 1/29/07, TW <twiebe at cityofwinkler.ca> wrote:
>> > Zak,
>> > Yes, the sdf file and shp files are in the library respository folder
>> on the
>> > server.
>> > However web studio will not allow me to create an unmanaged feature
>> source.
>> > Any suggestions? Is there more setting up to do with IIS?
>> > Zak James wrote:
>> > > Tim,
>> > > Can you search through the repository to see if the sdf file is
>> > > actually present on the server? I'm wondering if there is some IIS
>> > > specific issue with the upload mechanism. It works under apache.
>> > > Another thing you could try is creating an unmanaged feature source
>> > > (pointing it to a file/folder already on the server) to see if that
>> > > allows you to create a layer.
>> > > zak
>> > > On 1/26/07, TW <twiebe at cityofwinkler.ca> wrote:
>> > >> When I try to create a layer from an uploaded data source in web
>> studio
>> > >> it
>> > >> will not allow me to occupy the feature class or geometry fields to
>> setup
>> > >> the layer.
>> > >> Web studio will allow me to create a feature data source and upload
>> > >> either a
>> > >> shp file or sdf, and yes it does actual create a folder in the
>> > >> respoistory
>> > >> and makes it available.
>> > >> I am running the server on IIS 5. Am I missing something obvious? I
>> have
>> > >> used the enterprise software and it works fine. But I cannot use the
>> > >> Opensource.
>> > >> What am I missing?
>> > >> Tim
>> > >> View this message in context:
>> http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8657214
>> > >> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> > >> _______________________________________________
>> > >> mapguide-users mailing list
>> > >> mapguide-users at lists.osgeo.org
>> > >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> > > Zak James
>> > > Applications and Software Development
>> > > DM Solutions Group Inc.
>> > > http://www.dmsolutions.ca
>> http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8690301
>> Zak James
> Zak James
View this message in context: http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8713771
