[mapguide-users] MGOS 1.1.0 install
Knight, Gregory Gregory.Knight.bra at cityofboston.gov
Tue Jan 30 14:41:12 EST 2007
Hmm...
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Tuesday, January 30, 2007 2:09 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] MGOS 1.1.0 install
Odd.
I'm not an ASP.Net user, but...
Does your app have a local copy of the OSGeo assemblies in its bin
directory?  If so, did you refresh it?
Jason
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Knight,
Gregory
Sent: Tuesday, January 30, 2007 10:59
Subject: [mapguide-users] MGOS 1.1.0 install
I am attempting to upgrade to MGOS 1.1.0 from 1.0.1.  I completely
deinstalled 1.0.1, rebooted, then installed 1.1.0 with the.NET web
extensions.  When I try to run my app after the install, I get the
following error:
CS0246: The type or namespace name 'OSGeo' could not be found (are you
missing a using directive or an assembly reference?)
So, it would seem that the OSGeo.Mapguide .NET assembly isn't getting
registered properly.  I think I can confirm this by using the visual
studio object browser - where I can see other referenced assemblies;
like System.IO, System.Collections, etc. but see no OSGeo assemblies.
I didn't see any other threads reporting this issue... So two questions:
1.	Why me? :)
2.	How do I straighten this out?  At this point, Ive run through
the install procedure about 3 times.  Can I manually register the
assembly?
Thanks,
Greg
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070130/85134bdf/attachment-0001.html
