[mapguide-users] MGOS 1.1.0 install
Jason Birch Jason.Birch at nanaimo.ca
Tue Jan 30 14:09:01 EST 2007
Odd.
I'm not an ASP.Net user, but...
Does your app have a local copy of the OSGeo assemblies in its bin
directory?  If so, did you refresh it?
Jason
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Knight,
Gregory
Sent: Tuesday, January 30, 2007 10:59
To: MapGuide Users Mail List
Subject: [mapguide-users] MGOS 1.1.0 install
I am attempting to upgrade to MGOS 1.1.0 from 1.0.1.  I completely
deinstalled 1.0.1, rebooted, then installed 1.1.0 with the.NET web
extensions.  When I try to run my app after the install, I get the
following error:
CS0246: The type or namespace name 'OSGeo' could not be found (are you
missing a using directive or an assembly reference?)
So, it would seem that the OSGeo.Mapguide .NET assembly isn't getting
registered properly.  I think I can confirm this by using the visual
studio object browser - where I can see other referenced assemblies;
like System.IO, System.Collections, etc. but see no OSGeo assemblies.
I didn't see any other threads reporting this issue... So two questions:
1.	Why me? :)
2.	How do I straighten this out?  At this point, Ive run through
the install procedure about 3 times.  Can I manually register the
assembly?
Thanks,
Greg
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070130/5baa15ee/attachment.html
