[mapguide-users] MGOS 1.1.0 install
Andy Morsell amorsell at spatialgis.com
Tue Jan 30 14:08:18 EST 2007
I assume that you copied the new MapGuide dll files into your application's
bin folder?  I ran into some other .NET weirdness when I did the same
upgrade recently and found that deleting the folders in
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files forced
the applications to rebuild and did seem to help.
Andy
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Knight, Gregory
Sent: Tuesday, January 30, 2007 10:59 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] MGOS 1.1.0 install
I am attempting to upgrade to MGOS 1.1.0 from 1.0.1.  I completely
deinstalled 1.0.1, rebooted, then installed 1.1.0 with the.NET web
extensions.  When I try to run my app after the install, I get the following
error:
CS0246: The type or namespace name 'OSGeo' could not be found (are you
missing a using directive or an assembly reference?)
So, it would seem that the OSGeo.Mapguide .NET assembly isn't getting
registered properly.  I think I can confirm this by using the visual studio
object browser - where I can see other referenced assemblies; like
System.IO, System.Collections, etc. but see no OSGeo assemblies.
I didn't see any other threads reporting this issue. So two questions:
1.	Why me? :)
2.	How do I straighten this out?  At this point, Ive run through the
install procedure about 3 times.  Can I manually register the assembly?
Thanks,
Greg
  _____
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070130/569e3050/attachment.html
