[mapguide-users] RE: MgTileService - GetTile - Cannot
	establishconnection
    Traian Stanev
    traian.stanev at autodesk.com
    Tue Jan 30 19:00:12 EST 2007
Are you hoping to generate rasters at higher dpi for printing purposes?
Traian
	-----Original Message-----
	From: mapguide-users-bounces at lists.osgeo.org on behalf of Andy Morsell
	Sent: Tue 1/30/2007 6:29 PM
	To: mapguide-users at lists.osgeo.org
	Cc:
	Subject: [mapguide-users] RE: MgTileService - GetTile - Cannot establishconnection
	I just ran into a case where exposing a Set DPI method to the
	MgRenderingService::RenderMap function would be very handy and would allow
	more control by the programmer.  I hope it is a considered addition to the
	API soon.
	Thank you.
	Andy
	JasonBirch wrote:
	> I'm surprised that there are methods which are available to the MapAgent
	> but not the APIs.
	> Was this a case of deliberate exclusion, or not enough time to get
	> everything in?  I can see there being some arguments for not exposing
	> these methods (only need them for rendering, etc) but there are
	> apparently going to be some use cases for accessing them :)
	> Jason
	> ________________________________
	> From: Walt Welton-Lair
	> Sent: Thursday, December 07, 2006 15:47
	> To: users at mapguide.osgeo.org
	> Subject: RE: [mapguide-users] MgTileService - GetTile - Cannot establish
	> connection
	> Sorry about that - I forgot that the Set methods weren't exposed.
	> As Alain mentioned, currently the only way to update the view is via
	> certain HTTP requests.  GETMAP / GETMAPUPDATE / GETPLOT are used in the
	> context of DWFViewer, while GETMAPIMAGE and GETVISIBLEMAPEXTENT are used
	> in the context of AJAX Viewer.  You can include additional parameters
	> with any of these requests to update view related information:
	>     SETDISPLAYDPI=<dpi>
	>     SETDISPLAYWIDTH=<width>
	>     SETDISPLAYHEIGHT=<height>
	>     SETVIEWSCALE=<scale>
	>     SETVIEWCENTERX=<centerX>
	>     SETVIEWCENTERY=<centerY>
	> While you can use a viewer to make these requests for you, you can make
	> the HTTP requests yourself and get the same effect.  You could write an
	> application that:
	> 1) creates a session
	> 2) creates an MgMap for your MapDefinition that is part of your session
	> 3) makes one of the HTTP requests above
	>     - GETVISIBLEMAPEXTENT is the simplest
	>     - include the SETVIEWSCALE parameter with the request to set the
	> scale you want
	> 4) makes calls to GetTile
	> 5) repeats steps 3 and 4 for each desired scale
	> For steps 1 and 2 there's should be sample code under the MgMap
	> documentation.
	> For step 3 something like .NET's HttpRequest class probably works.  Just
	> make the request to your MG server, e.g.
	> http:://localhost/mapguide/mapagent?OPERATION=GETVISIBLEMAPEXTENT&VERSIO
	> N=1.0.0&SESSION=<sessionId>&MAPNAME=<mapName>&SETVIEWSCALE=<scale>
	> Here, mapName is the name from the MgMap.
	> Walt
	View this message in context: http://www.nabble.com/MgTileService---GetTile---Cannot-establish-connection-tf2763585s16610.html#a8720298
	mapguide-users mailing list
	http://lists.osgeo.org/mailman/listinfo/mapguide-users
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070130/16ac5abd/attachment.bin
