[mapguide-users] King Oracle Provider Version 0.5.1
Joel Carranza jec at gatekeeper.com
Wed Jan 31 14:57:58 EST 2007
I suspect I found the problem. The problem only occurs on layers using
the Oracle 9.2 instance. Our 10g instance works as expected.
Joel
Webo wrote:
> Hi Joel,
> I'm using King.Oracle provider 0.5.1 and the MGOS 1.1.0 without any
> problems. I made SQL trace and found that this provider uses spatial
> predicate SDO_ANYINTERACT.
> I also upgraded MGOS 1.0.1 with this one (1.1.0) which uses FDO 3.2 and it
> works same for me.
> Vedad
> Joel Carranza wrote:
>> Yes. I got a squeaky clean and new version of everything. No problems
>> with layer setup or anything like that. However, when I go and try and
>> view the map.... Everything just tanks. Oracle logs show that there is
>> no spatial predicate on table
>> Andy Morsell wrote:
>>> Did you get the latest version of the provider (version 0.5.1) which is
>>> based on FDO 3.2 which is what MGOS 1.1.0 is now using?
>>> http://www.sl-king.com/fdooracle/
>>> Andy
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joel
>>> Carranza
>>> Sent: Tuesday, January 30, 2007 5:08 PM
>>> To: MapGuide Users Mail List
>>> Subject: [mapguide-users] King Oracle Provider Version 0.5.1
>>> I have upgraded to Mapguide 1.1 and found that my King Oracle Provider is
>>> no
>>> longer working properly. It does not appear to be applying a spatial
>>> predicate on map requests, and thus quickly bog down with the volume of
>>> data
>>> returned. Anyone experinced similair problems? Am I missing something?
>>> -Joel
>>> Gatekeeper Systems
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070131/0aa18a71/attachment.html
