[mapguide-users] ODBC Provider with SQL Server 2005: Does it works
for somebody?
FGoulet
gouletf at dfo-mpo.gc.ca
Tue Jan 30 16:00:25 EST 2007
If yes, I would very like to know your configuration!
I have been trying to show a simple point layer from a SQL server 2005 db
without success.
Like I said in my previous post, this is the error I get from MGOS 1.1.0 log
file:
<2007-01-23T12:30:56> Anonymous
Error: Failed to stylize layer: DredgingActivity
An exception occurred in FDO component.
RDBMS: Incompatible column type
StackTrace:
- MgStylizationUtil.StylizeLayers line 993 file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\mapping\StylizationUtil.cpp
I you're using the FDO ODBC provider with SQLServer 2005, please share your
setup with me.
My setup:
Windows server 2003 sp1
MGOS 1.1.0 on IIS6
SQL Server 2005 Express sp1
Thanks!
Frederic Goulet
View this message in context: http://www.nabble.com/ODBC-Provider-with-SQL-Server-2005%3A-Does-it-works-for-somebody--tf3144880s16610.html#a8717853
