[mapguide-users] RE: Multiple Symbols in a Layer
Jim O'Leary
joleary.public at gmail.com
Tue Jan 30 15:33:04 EST 2007
I am thinking of symbols as digitized points, however. You cannot put more
than one symbol on one layer when you make markup, correct?
Thanks
Andy Morsell wrote:
> If you theme your layer you can assign different symbols to each theme
> rule.
> Or, if you use multiple scale ranges non-thematically, each range can have
> a
> different symbol assigned.
> Andy
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
> Sent: Tuesday, January 30, 2007 11:57 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Multiple Symbols in a Layer
> Is a layer contstrained to use one symbol only? It looks that way in the
> XML
> schema, where you record something like this for the W2D element:
> <W2D>
> <Unit>Millimeters</Unit>
> <SizeContext>DeviceUnits</SizeContext>
> <SizeX>15</SizeX>
> <SizeY>15</SizeY>
> <W2DSymbol>
> <ResourceId>Library://Gulfislands/Symbol
> libraries/GulfIslandSymbols.SymbolLibrary</ResourceId>
> <LibraryItemName>helicopter</LibraryItemName>
> </W2DSymbol>
> </W2D>
> Is there a way to make multiple symbols for a given layer?
> http://www.nabble.com/Multiple-Symbols-in-a-Layer-tf3144492s16610.html#a8716
> 637
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Multiple-Symbols-in-a-Layer-tf3144492s16610.html#a8717354
