[mapguide-users] Buffer rectangle
Martin Morrison
martin.morrison at edsi.com
Fri Jul 6 10:51:14 EDT 2007
A buffer is going to be the shape of a set distance from the edge of the
object selected. If you select a point, you get a circle with a radius
the size of your buffer. If you select a polygon you will get the rough
shape of the polygon offset by the size of the buffer.
Martin
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
Sent: Friday, July 06, 2007 10:38 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Buffer rectangle
Does MapGuide support rectangle buffers? It seems that the default
buffer it
produces is a circle.
Thanks.
View this message in context:
http://www.nabble.com/Buffer-rectangle-tf4035927s16610.html#a11465564
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
