[mapguide-users] RE: Buffer rectangle
Jim O'Leary
joleary.public at gmail.com
Fri Jul 6 10:54:26 EDT 2007
So you could select a point, make a small rectangle from it, and then make a
buffer, which would also be a rectangle.
Thanks.
Martin Morrison wrote:
> A buffer is going to be the shape of a set distance from the edge of the
> object selected. If you select a point, you get a circle with a radius
> the size of your buffer. If you select a polygon you will get the rough
> shape of the polygon offset by the size of the buffer.
> Martin
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
> Sent: Friday, July 06, 2007 10:38 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Buffer rectangle
> Does MapGuide support rectangle buffers? It seems that the default
> buffer it
> produces is a circle.
> Thanks.
> http://www.nabble.com/Buffer-rectangle-tf4035927s16610.html#a11465564
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Buffer-rectangle-tf4035927s16610.html#a11465860
