[mapguide-users] RE: Buffer rectangle
Martin Morrison martin.morrison at edsi.com
Fri Jul 6 11:05:21 EDT 2007
Yes, but keep in mind that the corners of your buffer will be rounded.
Martin
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
Sent: Friday, July 06, 2007 10:54 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: Buffer rectangle
So you could select a point, make a small rectangle from it, and then
make a
buffer, which would also be a rectangle.
Thanks.
Martin Morrison wrote:
> A buffer is going to be the shape of a set distance from the edge of
the
> object selected.  If you select a point, you get a circle with a
radius
> the size of your buffer.  If you select a polygon you will get the
rough
> shape of the polygon offset by the size of the buffer.
> Martin
> From: mapguide-users-bounces at lists.osgeo.org
O'Leary
> Sent: Friday, July 06, 2007 10:38 AM
> Subject: [mapguide-users] Buffer rectangle
> Does MapGuide support rectangle buffers? It seems that the default
> buffer it
> produces is a circle.
> Thanks.
> http://www.nabble.com/Buffer-rectangle-tf4035927s16610.html#a11465564
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://www.nabble.com/Buffer-rectangle-tf4035927s16610.html#a11465860
