[mapguide-users] RE: RE: Buffer rectangle
Jim O'Leary
joleary.public at gmail.com
Sun Jul 8 15:55:01 EDT 2007
I am already calling the Buffer() method from an MgGeometry polygon with an
arbitrary number of x,y coordinates. However, the buffer that the method
returns is a circle, and not the shape of that polygon.
I took my code from the Autodesk Dev Guide sample
selectfeaturesinbuffer.php, and also from buffer.php in the mapviewerphp
folder. Both of those programs also return a round buffer from an MgGeometry
polygon. Does this mean it is not possible to produce a rectangle polygon?
Thanks
Martin Morrison wrote:
> Yes, but keep in mind that the corners of your buffer will be rounded.
> Martin
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
> Sent: Friday, July 06, 2007 10:54 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: Buffer rectangle
> So you could select a point, make a small rectangle from it, and then
> make a
> buffer, which would also be a rectangle.
> Thanks.
>> A buffer is going to be the shape of a set distance from the edge of
> the
>> object selected. If you select a point, you get a circle with a
> radius
>> the size of your buffer. If you select a polygon you will get the
> rough
>> shape of the polygon offset by the size of the buffer.
>> Martin
> O'Leary
>> Sent: Friday, July 06, 2007 10:38 AM
>> Subject: [mapguide-users] Buffer rectangle
>> Does MapGuide support rectangle buffers? It seems that the default
>> buffer it
>> produces is a circle.
>> Thanks.
>> View this message in context:
>> http://www.nabble.com/Buffer-rectangle-tf4035927s16610.html#a11465564
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Buffer-rectangle-tf4035927s16610.html#a11465860
View this message in context: http://www.nabble.com/Buffer-rectangle-tf4035927s16610.html#a11492134
