[mapguide-users] Using elevation / height information in
mapguide (srtm)
Eduard Witteveen
mapguide-users at nergens.org
Sun Jul 8 12:31:49 EDT 2007
On Mon, 2007-07-02 at 12:47 -0700, RichBauer wrote:
> SID raster data. I can't tell if yours is exactly the same since I am not
> extremely knowledgeable on this subject and using the info given, but the
> following thread might be of help. It fixed mine perfectly. This was on
I changed the dll's, i see now a little bit more, but still not what i
would expect.
> C:\SharedFolder\srtm\version2\SRTM30\e020n90>dir
> Volume in drive C has no label.
> Volume Serial Number is 5C2D-CA72
> Directory of C:\SharedFolder\srtm\version2\SRTM30\e020n90
> 07/06/2007 03:56 PM <DIR> .
> 07/06/2007 03:56 PM <DIR> ..
> 02/02/2006 03:04 PM 57,600,000 E020N90.DEM
> 02/02/2006 03:04 PM 57,600,000 E020N90.DIF
> 02/02/2006 03:04 PM 222 E020N90.DMW
> 07/06/2007 03:44 PM 360 E020N90.HDR
> 02/02/2006 03:04 PM 28,800,000 E020N90.NUM
> 02/02/2006 03:04 PM 648 E020N90.PRJ
> 02/02/2006 03:04 PM 325 E020N90.SCH
> 02/02/2006 03:04 PM 28,800,000 E020N90.SRC
> 02/02/2006 03:04 PM 57,600,000 E020N90.STD
> 02/02/2006 03:04 PM 28 E020N90.STX
> 10 File(s) 230,401,583 bytes
> 2 Dir(s) 5,185,933,312 bytes free
I've also added the following line:
> PIXELTYPE SIGNEDINT
to the file: E020N90.HDR which contains the following information:
> BYTEORDER M
> LAYOUT BIL
> NROWS 6000
> NCOLS 4800
> NBANDS 1
> NBITS 16
> BANDROWBYTES 9600
> TOTALROWBYTES 9600
> BANDGAPBYTES 0
> NODATA -9999
> ULXMAP 20.00416666666667
> ULYMAP 89.99583333333334
> XDIM 0.00833333333333
> YDIM 0.00833333333333
|Configuration of the resource: http://nergens.org/projects/mapguide%
20os/resource.png
Configuration of the layer: http://nergens.org/projects/mapguide%
20os/layer.png <-- NOTICE THE GREY DOTS!
btw: maybe it wasnt clear from the previous email, im using MapGuide
Open Source 1.1.0, and i use autodesk mapguide studion to configure
stuff
Eduard
