[mapguide-users] Using elevation / height information in
mapguide (srtm)
RichBauer
rdbauer at gmail.com
Mon Jul 2 15:47:43 EDT 2007
Eduard,
It sounds like a similar problem to what I had. Mine, however, was using
SID raster data. I can't tell if yours is exactly the same since I am not
extremely knowledgeable on this subject and using the info given, but the
following thread might be of help. It fixed mine perfectly. This was on
1.1.0 version so if yours is not, then it might be different.
http://www.nabble.com/SID-Raster-Problem-tf3853167s16610.html#a10918776
Good luck.
Rich
Eduard Witteveen-4 wrote:
> Hello list,
> I want to display height information inside my gisviewer, and offer the
> possibility to click and show the altitude.
> I've found data on the internet, the srtm
> (http://www2.jpl.nasa.gov/srtm/) and i try to load this data into
> mapguide opensource, without any luck. After extracting the data i have
> the following files (which look interresting):
> fileextensions:
> std, dif, dem, src, num, hgt, jpg, gif
> Since the following files are the biggest i started with the files "std,
> dif, dem" to put them into mapguide as rasterdata (AFAIK rasterdata
> should use GDAL and GDAL supports(http://www.gdal.org/formats_list.html)
> dem, jpg and gif. The jpg and gif are really not as accurate as i want
> and since the dem file is much bigger, i tried to load the dem data.
> After loading the data into mapguide nothing is showing:
> The feature resource(OSGeo.Gdal) reports with testing: "succesful
> connection", but when i want to do a layer preview, i don't see
> anything.
> CAN someone tell me how to get the dem file loaded into mapguide and
> maybe give me a pointer to show the altitude from a certain location?
> ps: i did some searches on the internet on srtm, but all i could find
> were sample's which used the wms (http://wms.jpl.nasa.gov/wms.cgi)
> directly
> Eduard
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Using-elevation---height-information-in-mapguide-%28srtm%29-tf4014400s16610.html#a11400437
