[mapguide-users] UnManagedData Slow
Bruce Dechant bruce.dechant at autodesk.com
Mon Jul 9 12:43:29 EDT 2007
SDF and SHP are excluded from pooling because of an update/reader issue
within FDO that has not been addressed yet.
If you notice some problems with update/readers then you should leave it
as excluded. I believe this is planned to be fixed with the next release
of FDO post MGOS 1.2.
Thanks,
Bruce
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nichols,
David
Sent: July 5, 2007 10:23 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] UnManagedData Slow
That did it!!  Thanks.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Thursday, July 05, 2007 11:32 AM
To: 'MapGuide Users Mail List'
See this existing trac ticket on this topic:
http://trac.osgeo.org/mapguide/ticket/175.  If you enable pooling for
SDF (I believe SDF by default is excluded from pooling in
serverconfig.ini) you should see the same performance increase noted in
the ticket.  The development team is aware of these issues and have set
the milestone for this to be fixed in release 1.3
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of nicholda
Sent: Thursday, July 05, 2007 5:58 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] UnManagedData Slow
Hi all,
I hope someone can point me in the right direction, I am using 1.2 and
have re-mapped data to a location on disk.  I am seeing a noticeable
difference in response time between managed and unmanaged data.  I
re-mapped my feature source as shown below.
Original
<?xml version="1.0" encoding="utf-8"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
  <Provider>OSGeo.SDF</Provider>
  <Parameter>
    <Name>File</Name>
    <Value>>%MG_DATA_FILE_PATH%AsBuiltBldgs.sdf</Value>
  </Parameter>
  <Parameter>
    <Name>ReadOnly</Name>
    <Value>TRUE</Value>
  </Parameter>
</FeatureSource>
Modified
  <Parameter>
    <Name>File</Name>
    <Value>E:/FME_Data/mgos/AsBuiltBldgs.sdf</Value>
  </Parameter>
  <Parameter>
    <Value>FALSE</Value>
  </Parameter>
</FeatureSource>
After re-mapping I added the following alias to the serverconfig.ini
file.
[UnmanagedDataMappings]
UnmanagedSdf = E:\FME_Data\mgos
I then used the EnumerateUnmanagedData API to get the following.  But I
am not sure what to do next.
  <?xml version="1.0" encoding="UTF-8"?> <UnmanagedDataList
xsi:noNamespaceSchemaLocation="UnmanagedDataList-1.0.0.xsd">
	<UnmanagedDataFile>
<UnmanagedDataId>[UnmanagedSdf]AsBuiltBldgs.sdf</UnmanagedDataId>
		<CreatedDate>2007-06-28T13:00:40Z</CreatedDate>
		<ModifiedDate>2007-06-28T13:00:40Z</ModifiedDate>
		<Size>563200</Size>
	</UnmanagedDataFile>
</UnmanagedDataList>
Am I on the right track for improved performance/response time or am I
completely off base.  Any suggestions are welcomed.
Thanks,
David
View this message in context:
http://www.nabble.com/UnManagedData-Slow-tf4029540s16610.html#a11445964
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
This footnote confirms that this email message has been scanned by
PineApp Mail-SeCure for the presence of malicious code, vandals &
computer viruses.
computer viruses.
