[mapguide-users] UnManagedData Slow
Nichols, David
nicholda at talgov.com
Thu Jul 5 12:23:21 EDT 2007
That did it!! Thanks.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
Morsell
Sent: Thursday, July 05, 2007 11:32 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] UnManagedData Slow
See this existing trac ticket on this topic:
http://trac.osgeo.org/mapguide/ticket/175. If you enable pooling for
SDF (I believe SDF by default is excluded from pooling in
serverconfig.ini) you should see the same performance increase noted in
the ticket. The development team is aware of these issues and have set
the milestone for this to be fixed in release 1.3
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of nicholda
Sent: Thursday, July 05, 2007 5:58 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] UnManagedData Slow
Hi all,
I hope someone can point me in the right direction, I am using 1.2 and
have re-mapped data to a location on disk. I am seeing a noticeable
difference in response time between managed and unmanaged data. I
re-mapped my feature source as shown below.
Original
<?xml version="1.0" encoding="utf-8"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
<Provider>OSGeo.SDF</Provider>
<Parameter>
<Name>File</Name>
<Value>>%MG_DATA_FILE_PATH%AsBuiltBldgs.sdf</Value>
</Parameter>
<Parameter>
<Name>ReadOnly</Name>
<Value>TRUE</Value>
</Parameter>
</FeatureSource>
Modified
<Parameter>
<Name>File</Name>
<Value>E:/FME_Data/mgos/AsBuiltBldgs.sdf</Value>
</Parameter>
<Parameter>
<Value>FALSE</Value>
</Parameter>
</FeatureSource>
After re-mapping I added the following alias to the serverconfig.ini
file.
[UnmanagedDataMappings]
UnmanagedSdf = E:\FME_Data\mgos
I then used the EnumerateUnmanagedData API to get the following. But I
am not sure what to do next.
<?xml version="1.0" encoding="UTF-8"?> <UnmanagedDataList
xsi:noNamespaceSchemaLocation="UnmanagedDataList-1.0.0.xsd">
<UnmanagedDataFile>
<UnmanagedDataId>[UnmanagedSdf]AsBuiltBldgs.sdf</UnmanagedDataId>
<CreatedDate>2007-06-28T13:00:40Z</CreatedDate>
<ModifiedDate>2007-06-28T13:00:40Z</ModifiedDate>
<Size>563200</Size>
</UnmanagedDataFile>
</UnmanagedDataList>
Am I on the right track for improved performance/response time or am I
completely off base. Any suggestions are welcomed.
Thanks,
David
View this message in context:
http://www.nabble.com/UnManagedData-Slow-tf4029540s16610.html#a11445964
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
This footnote confirms that this email message has been scanned by
PineApp Mail-SeCure for the presence of malicious code, vandals &
computer viruses.
PineApp Mail-SeCure for the presence of malicious code, vandals & computer viruses.
