[mapguide-users] RE: Coords files on 64 bit machine
Traian Stanev traian.stanev at autodesk.com
Tue Jul 10 13:38:46 EDT 2007
I wonder if the registry key is different from what MG expects. May be
you can create a key whose name matches what is on a 32 bit machine (so
without the Wow6432 node).
Traian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
Sent: Tuesday, July 10, 2007 12:29 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: Coords files on 64 bit machine
Yes, MapGuide on 64 bit installs to
C:\Program Files (x86)\
The coords files thus install to
C:\Program Files (x86)\Common Files\Autodesk Shared\Gis\CoordSys\11g
This is the correct path setting in the registry key. There are no other
coords files on the machine, so Studio is definitely reading those
dictionary files. It is just not picking up the BC Albers definition
when I
replace those coords files.
Andy Morsell wrote:
> I've only worked with MGOS on an 64 bit machine, but in that case, all
32
> bit programs are installed under the Program Files (x86) folder rather
> than
> Program Files.  Are you sure that isn't where you should be copying
the
> files to instead?
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> From: mapguide-users-bounces at lists.osgeo.org
O'Leary
> Sent: Tuesday, July 10, 2007 8:45 AM
> Subject: [mapguide-users] Coords files on 64 bit machine
> We need the BC Albers coordinate system in our MapGuide dictionary.
With
> the
> current MGE I am able to change the coordsys.CSD and category.CSD
files as
> this posting suggests:
> http://discussion.autodesk.com/thread.jspa?threadID=514332
> .by copying them to the
> C:\Program Files\Common Files\Autodesk Shared\Gis\CoordSys\11e
> folder. At that point, BC Albers shows up in Studio under Canada
> Provinces.
> However, this does not work with MGE 2008, possibly because we have a
64
> bit
> machine. Looking at the registry settings, I can see that the
> HKEY_LOCAL_MACHINE -> SOFTWARE -> Wow6432Node -> Autodesk -> GIS
->Coorsys
> ->11g keys map correctly to the Category.CSD and Coordsys.CSD files.
> However, BC Albers does not show up in Studio.
> Has anyone had this experience on a 64 bit machine? Any solutions?
> Thanks
http://www.nabble.com/Coords-files-on-64-bit-machine-tf4056645s16610.htm
l#a1
> 1523589
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
l#a11524382
