[mapguide-users] RE: RE: Coords files on 64 bit machine
Jim O'Leary
joleary.public at gmail.com
Tue Jul 10 13:52:27 EDT 2007
According to Bruce Dechant, who I believe did some research on this topic,
Only native 64 bit applications can use the HKEY_LOCAL_MACHINE\Software\
location directly. 32bit applications will seamlessly be redirected to the
above registry key when requesting HKEY_LOCAL_MACHINE\Software\
MG is obviously reading the coords files where they reside. It just doesn't
read the BC Albers. Perhaps those coords files need to be recreated in Map
3D on a 64 bit machine?
Traian Stanev wrote:
> I wonder if the registry key is different from what MG expects. May be
> you can create a key whose name matches what is on a 32 bit machine (so
> without the Wow6432 node).
> Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
> Sent: Tuesday, July 10, 2007 12:29 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: Coords files on 64 bit machine
> Yes, MapGuide on 64 bit installs to
> C:\Program Files (x86)\
> The coords files thus install to
> C:\Program Files (x86)\Common Files\Autodesk Shared\Gis\CoordSys\11g
> This is the correct path setting in the registry key. There are no other
> coords files on the machine, so Studio is definitely reading those
> dictionary files. It is just not picking up the BC Albers definition
> when I
> replace those coords files.
> Andy Morsell wrote:
>> I've only worked with MGOS on an 64 bit machine, but in that case, all
> 32
>> bit programs are installed under the Program Files (x86) folder rather
>> than
>> Program Files. Are you sure that isn't where you should be copying
> the
>> files to instead?
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> http://www.SpatialGIS.com
> O'Leary
>> Sent: Tuesday, July 10, 2007 8:45 AM
>> Subject: [mapguide-users] Coords files on 64 bit machine
>> We need the BC Albers coordinate system in our MapGuide dictionary.
> With
>> the
>> current MGE I am able to change the coordsys.CSD and category.CSD
> files as
>> this posting suggests:
>> http://discussion.autodesk.com/thread.jspa?threadID=514332
>> .by copying them to the
>> C:\Program Files\Common Files\Autodesk Shared\Gis\CoordSys\11e
>> folder. At that point, BC Albers shows up in Studio under Canada
>> Provinces.
>> However, this does not work with MGE 2008, possibly because we have a
> 64
>> bit
>> machine. Looking at the registry settings, I can see that the
>> HKEY_LOCAL_MACHINE -> SOFTWARE -> Wow6432Node -> Autodesk -> GIS
> ->Coorsys
>> ->11g keys map correctly to the Category.CSD and Coordsys.CSD files.
>> However, BC Albers does not show up in Studio.
>> Has anyone had this experience on a 64 bit machine? Any solutions?
>> Thanks
>> View this message in context:
> http://www.nabble.com/Coords-files-on-64-bit-machine-tf4056645s16610.htm
> l#a1
>> 1523589
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> l#a11524382
View this message in context: http://www.nabble.com/Coords-files-on-64-bit-machine-tf4056645s16610.html#a11526040
