[mapguide-users] Re: mapguide-users Digest, Vol 6, Issue 30
consultorweb at comprandofacil.com consultorweb at comprandofacil.com
Tue Jul 10 16:22:15 EDT 2007
Hola a todos desde colombia
He instalado el mapqguide open source 1.2 y apenas estoy comenzando con esto
y tengo las siguientes dudas con el web studio:
1. Intento cargar un .shp y cuando le digo a la capa que me carge la
informacio de este no sale nada
2. Esta herramienta soporta conexiones al sql server ?
Sinceramente  me siento perdido,  cuando intento ver los archivos de ayuda
siempre sale que no encuentra la pagina
Quien me puede colaborar???
gracias
----- Original Message -----
To: <mapguide-users at lists.osgeo.org>
Sent: Saturday, June 30, 2007 11:00 AM
Subject: mapguide-users Digest, Vol 6, Issue 30
> Send mapguide-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> mapguide-users-request at lists.osgeo.org
> You can reach the person managing the list at
> mapguide-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of mapguide-users digest..."
> Today's Topics:
>   1. Clear Selection (RichBauer)
>   2. Re: linux wms problem solved. (BradM)
>   3. RE: Clear Selection (Chris Claydon)
> Message: 1
> Date: Fri, 29 Jun 2007 13:17:54 -0700 (PDT)
> From: RichBauer <rdbauer at gmail.com>
> Subject: [mapguide-users] Clear Selection
> To: mapguide-users at lists.osgeo.org
> Message-ID: <11366536.post at talk.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Has anyone experienced the problem of when say a parcel (polygon) is
> selected
> and the properties display just fine and then you use the "Clear
> Selection"
> command from the right-click menu, the highlighting clears, but the
> properties window does not clear?  If so, is there a way to fix it?  It is
> not a big deal, just for cleanliness.  Thanks.
> Rich
> http://www.nabble.com/Clear-Selection-tf4001770s16610.html#a11366536
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Message: 2
> Date: Fri, 29 Jun 2007 14:16:58 -0700 (PDT)
> From: BradM <masonb at dfo-mpo.gc.ca>
> Subject: Re: [mapguide-users] linux wms problem solved.
> Message-ID: <11367308.post at talk.nabble.com>
> now that WMS is working,  I would like to see a tool for users to select a
> WMS source they want by typing in the url or by selecting from a list,
> then
> the user should be able to select a specific map layer and then select the
> order the map layer(s) should be displayed in.  Is this possible? Can
> anybody help make this tool?
> thanks
> larry white-6 wrote:
>> Jason,
>> no, i haven't filed a report yet. just got it figured out yesterday, so
>> i wanted to share it with the community first to see if this had come up
>> previously and i missed it.
>> uh.... actually, i haven't filed any bug reports yet, and there are a
>> couple of other things i found recently that probably should also be
>> reported. will do so sometime today or over the weekend.
>> i've implemented this fix in the most recent release of mgos - 1.2rc2.
>> so, perhaps the windows projection test failures are related.
>> (i've been struggling with this since very early 1.0x versions)
>> larry white
>> Senior Systems Analyst
>> Neomatix Corporation
>> email: larz at neomatix.ca
>> url: www.neomatix.ca
>> Jason Birch wrote:
>>> larry white wrote:
>>>> a file, 'categories.txt', is in the wrong place.
>>>> it should be in the PROJ_LIB dir
>>>> (.../server/bin/nad), but currently resides in .../server/bin.
>>> That's interesting.  Have you filed a bug report on this one yet?
>>> I'm wondering if this is the same reason that the mapagent projection
>>> tests are failing in Win32 with MGOS 1.2.0.  What version are you using?
>>> Thanks,
>>> Jason
> http://www.nabble.com/linux-wms-problem-solved.-tf4000152s16610.html#a11367308
> Message: 3
> Date: Fri, 29 Jun 2007 14:38:02 -0700
> From: "Chris Claydon" <chris.claydon at autodesk.com>
> Subject: RE: [mapguide-users] Clear Selection
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Message-ID:
> <73BD5EF42E005C47988D1624D128BC7E084B9F94 at msgusawmb03.ads.autodesk.com>
> Content-Type: text/plain; charset="US-ASCII"
> This issue is described in trac ticket 37...
> http://trac.osgeo.org/mapguide/ticket/37
> It was fixed about three months ago. Which version of MapGuide are you
> seeing this with?
> Chris.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of RichBauer
> Sent: June 29, 2007 2:18 PM
> selected
> Selection"
> is
> Rich
> End of mapguide-users Digest, Vol 6, Issue 30
