[mapguide-users] how to check setselection is on?
Jackie Ng jackie.ng at aecsystems.com.au
Tue Jul 10 20:27:41 EDT 2007
On the client side, you can call the GetSelectedCount() method on the
viewer's mapFrame, which will return the number of selected objects.
On the server side, you can create an MgSelection object on the current
MgMap object, and interrogate that object.
- Jackie
macieksk wrote:
> Hi all!
> How can i check that user make setselection() (object is selected - it
> is blue on map)...
> Maciej Skórczewski
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/how-to-check-setselection-is-on--tf4055958s16610.html#a11532179
