[mapguide-users] Installation assistance
Rock Beans
rockbeans at gmail.com
Wed Jul 11 15:08:17 EDT 2007
Did you copy the PHP MapGuide extensions to your existing ExtDir? For
example the php_MapGuideApi.dll file. You can find the location in your
existing PHP.INI file. When Map Guide installs it hard codes the PHP Ext to
"C:\Program Files\MapGuideOpenSource\WebServerExtensions\Php\ext" those
files and any other needed files on the PHP root need to be copied
accordingly. It won't hurt to have a seconf PHP folder on your server. Some
would find this more custom and secure based on the applications needs.
I also would like to see some real documentation in setting up the web
extent ions with an existing PHP installation.
The Rock
On 7/11/07, David Nuell <nuell at nicholsenvironmental.com> wrote:
> Hi Listers -
> Here is the scoop. I am running a Windows 2003 Server with IIS6 and PHP
> 5.2.1 (no apache, no tomcat). I have a wiki set up for our company that
> uses the PHP 5.2.1 (successfully). I have read on the 1.2.0RC2 download
> site that PHP5.2.1 should work with this version.
> I have installed 1.2.0RC2 onto the server and have gone through the
> install document (Installing and Configuring on Windows). I have set
> all relevant PHP look ups from the MapGuideOpenSource directory to the
> location on the server where I installed PHP 5.2.1 (i.e., C:\PHP\).
> After installation, I get the following:
> Testing Map Agent: the XML Document shows
> Testing Site Administrator: The log in screen shows. I input
> Administrator and admin as the L/P and the next screen shows up blank.
> The source code for the page is also blank.
> Testing Web Server Extensions: The page can not be found.
> I have been reading through the archives for similar issues and have
> read relevant posts. Nothing has yet been the answer to my issue stated
> above. Can someone out there lend me their expert advice? I would be
> greatly appreciative.
> David
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070711/6d21edf3/attachment.html
