[mapguide-users] Adding commands to WebLayout at runtime
Jackie Ng jackie.ng at aecsystems.com.au
Fri Jul 13 04:58:20 EDT 2007
You might want to take a look at mainframe.aspx/php/jsp in the
mapviewer(net/php/java) directory. The code there creates the
javascript/html for the toolbar/taskbar items from the weblayout definition.
- Jackie
Ismael Cams wrote:
> Hello,
> I am looking for a way to add flyout menus to the weblayout at runtime.
> The information that will be stored in the menus is session sensitive.
> Therefore adapting the Weblayout xml and uploading it to the repository is
> not a possibility.
> Can this be done without recreating the toolbar myself ?
View this message in context: http://www.nabble.com/Adding-commands-to-WebLayout-at-runtime-tf4029140s16610.html#a11575755
