[mapguide-users] Adding commands to WebLayout at runtime
Kenneth, GEOGRAF A/S
ks at geograf.dk
Fri Jul 13 06:08:48 EDT 2007
Or, you can upload a modified weblayout to the session repository
immediatly after the call to "create session", and then use the modified
layout from there. This way, the viewer will do all the work.
I assume that you handle the "create session" call manually.
Regards, Kenneth, GEOGRAF A/S
Jackie Ng skrev:
> Hi,
> You might want to take a look at mainframe.aspx/php/jsp in the
> mapviewer(net/php/java) directory. The code there creates the
> javascript/html for the toolbar/taskbar items from the weblayout definition.
> - Jackie
> Ismael Cams wrote:
>> Hello,
>> I am looking for a way to add flyout menus to the weblayout at runtime.
>> The information that will be stored in the menus is session sensitive.
>> Therefore adapting the Weblayout xml and uploading it to the repository is
>> not a possibility.
>> Can this be done without recreating the toolbar myself ?
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070713/49d245dd/attachment.html
