[mapguide-users] MapGuide Interactive Crash
Rock Beans
rockbeans at gmail.com
Fri Jul 13 14:40:45 EDT 2007
I can run the server as a windows service (as installed) and it seems to run
fine. I am having a freeze up issue after running about 20-30 buffers in a
row so I wanted to debug with /interactive. The message below is confusing.
Keep in mind it works as Windows service. I am running Vista if it matters
any. I also disable the windows service before attepting to run the server
in interactive mode. Just wanted to get the noobie questions out of the way.
Here is the batch file that runs the server:
cd "C:\Program Files\MapGuideOpenSource\Server\Bin"
mgserver.exe /interactive
pause
Here is the error output:
C:\Program Files\MapGuideOpenSource\Server\Bin>mgserver.exe /interactive
Running the server interactively as an application instead of as a service.
(3072|5828) An exception occurred in DB component.
DbEnv::dbremove: Operation not permitted
Exception occurred in method MgRepositoryManager.CleanRepository at line 330
in
file
c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\se
rvices\resource\RepositoryManager.cpp
(3072|5828) Server stopped.
C:\Program Files\MapGuideOpenSource\Server\Bin>pause
Press any key to continue . . .Help Help...Me!
The Rock
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070713/8bc1b21a/attachment.html
