[mapguide-users] MapGuide Interactive Crash
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Jul 16 02:58:03 EDT 2007
It would appear that the interactive version does not have permission to
do an initial clean of the repository.
Perhaps you run it with a limited account? I have not tried vista, but
on Windows XP and 2003, the service runs under "Local Service" and has
close to Administrative rights. You should be able to right click your
.bat file and select the "Run As..." option to run it as Administrator.
Regards, Kenneth, GEOGRAF A/S
Rock Beans skrev:
> I can run the server as a windows service (as installed) and it seems
> to run fine. I am having a freeze up issue after running about 20-30
> buffers in a row so I wanted to debug with /interactive. The message
> below is confusing. Keep in mind it works as Windows service. I am
> running Vista if it matters any. I also disable the windows service
> before attepting to run the server in interactive mode. Just wanted to
> get the noobie questions out of the way.
> Here is the batch file that runs the server:
> cd "C:\Program Files\MapGuideOpenSource\Server\Bin"
> mgserver.exe /interactive
> pause
> Here is the error output:
> C:\Program Files\MapGuideOpenSource\Server\Bin>mgserver.exe /interactive
> Running the server interactively as an application instead of as a
> service.
> (3072|5828) An exception occurred in DB component.
> DbEnv::dbremove: Operation not permitted
> Exception occurred in method MgRepositoryManager.CleanRepository at
> line 330 in
> file
> c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\se
> rvices\resource\RepositoryManager.cpp
> (3072|5828) Server stopped.
> C:\Program Files\MapGuideOpenSource\Server\Bin>pause
> Press any key to continue . . .Help Help...Me!
> The Rock
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070716/4601cc75/attachment.html
