[mapguide-users] A best map service
Do Xuan Quan
quandx at gmail.com
Mon Jul 16 22:02:49 EDT 2007
Hi all.
I have known a website that is a good map web.
Does anyone find out what a advantage and disadvantage
Thanks.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
GEOGRAF A/S
Sent: Monday, July 16, 2007 1:58 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MapGuide Interactive Crash
It would appear that the interactive version does not have permission to do
an initial clean of the repository.
Perhaps you run it with a limited account? I have not tried vista, but on
Windows XP and 2003, the service runs under "Local Service" and has close to
Administrative rights. You should be able to right click your .bat file and
select the "Run As..." option to run it as Administrator.
Regards, Kenneth, GEOGRAF A/S
Rock Beans skrev:
I can run the server as a windows service (as installed) and it seems to run
fine. I am having a freeze up issue after running about 20-30 buffers in a
row so I wanted to debug with /interactive. The message below is confusing.
Keep in mind it works as Windows service. I am running Vista if it matters
any. I also disable the windows service before attepting to run the server
in interactive mode. Just wanted to get the noobie questions out of the way.
Here is the batch file that runs the server:
cd "C:\Program Files\MapGuideOpenSource\Server\Bin"
mgserver.exe /interactive
pause
Here is the error output:
C:\Program Files\MapGuideOpenSource\Server\Bin>mgserver.exe /interactive
Running the server interactively as an application instead of as a service.
(3072|5828) An exception occurred in DB component.
DbEnv::dbremove: Operation not permitted
Exception occurred in method MgRepositoryManager.CleanRepository at line 330
in
file
c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\se
rvices\resource\RepositoryManager.cpp
(3072|5828) Server stopped.
C:\Program Files\MapGuideOpenSource\Server\Bin>pause
Press any key to continue . . .Help Help...Me!
The Rock
_____
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070717/de55577b/attachment.html
